Grafik aus Excelsheet in Shapes speichern und Transparenz beibehalten
Begonnen von Blaupunkt79, März 15, 2024, 10:39:52
Blaupunkt79
Hallo Zusammen,
ich habe folgenden Code aus dem Netz, um eine Grafik (transparentes gif) aus einem Excelsheet in einem Shape zu speichern. Im Shape geht allerdings die Transparenz verloren, wie erhalte ich diese?
Option Private Module
Private Declare PtrSafe Function OleCreatePictureIndirect Lib "oleaut32.dll" ( _
    ByRef PicDesc As PICT_DESC, _
    ByRef RefIID As GUID, _
    ByVal fPictureOwnsHandle As LongPtr, _
    ByRef IPic As IPicture) As LongPtr
Private Declare PtrSafe Function CopyImage Lib "user32.dll" ( _
    ByVal handle As LongPtr, _
    ByVal un1 As Long, _
    ByVal n1 As Long, _
    ByVal n2 As Long, _
    ByVal un2 As Long) As LongPtr
Private Declare PtrSafe Function IsClipboardFormatAvailable Lib "user32.dll" ( _
    ByVal wFormat As Long) As Long
Private Declare PtrSafe Function OpenClipboard Lib "user32.dll" ( _
    ByVal hwnd As LongPtr) As Long
Private Declare PtrSafe Function GetClipboardData Lib "user32.dll" ( _
    ByVal wFormat As Long) As LongPtr
Private Declare PtrSafe Function CLSIDFromString Lib "ole32.dll" ( _
    ByVal lpsz As Any, _
    ByRef pCLSID As GUID) As Long
Private Declare PtrSafe Function EmptyClipboard Lib "user32.dll" () As Long
Private Declare PtrSafe Function CloseClipboard Lib "user32.dll" () As Long
Private Type GUID
    Data1 As Long
    Data2 As Integer
    Data3 As Integer
    Data4(0 To 7) As Byte
End Type
Private Type PICT_DESC
    lSize As Long
    lType As Long
    hPic As LongPtr
    hPal As LongPtr
End Type
Private Const PICTYPE_BITMAP As Long = 1
Private Const CF_BITMAP As Long = 2
Private Const IMAGE_BITMAP As Long = 0
Private Const LR_COPYRETURNORG As Long = &H4
Private Const GUID_IPICTUREDISP As String = "{7BF80981-BF32-101A-8BBB-00AA00300CAB}"
Private Function PastePicture(ByRef prlngptrCopy As LongPtr) As IPictureDisp
    Dim lngReturn As Long, lngptrPointer As LongPtr
    If IsClipboardFormatAvailable(CF_BITMAP) = 1 Then
        lngReturn = OpenClipboard(CLngPtr(Application.hwnd))
        If lngReturn > 0 Then
            lngptrPointer = GetClipboardData(CF_BITMAP)
            prlngptrCopy = CopyImage(lngptrPointer, _
                IMAGE_BITMAP, 0&, 0&, LR_COPYRETURNORG)
            Call CloseClipboard
            If lngptrPointer <> 0 Then Set PastePicture = _
                CreatePicture(prlngptrCopy, 0)
Private Function CreatePicture( _
    ByVal lngptrhPic As LongPtr, _
    ByVal lngptrhPal As LongPtr) As IPictureDisp
    Dim udtPicInfo As PICT_DESC, udtID_IDispatch As GUID
    Dim objPicture As IPictureDisp
    Call CLSIDFromString(StrPtr( _
        GUID_IPICTUREDISP), udtID_IDispatch)
    With udtPicInfo
        .lSize = Len(udtPicInfo)
        .lType = PICTYPE_BITMAP
        .hPic = lngptrhPic
        .hPal = lngptrhPal
    End With
    Call OleCreatePictureIndirect(udtPicInfo, _
        udtID_IDispatch, 0&, objPicture)
    Set CreatePicture = objPicture
    Set objPicture = Nothing
Public Sub ShowPicture()
    Dim lngptrCopy As LongPtr
Set wb = ActiveWorkbook
    Call OpenClipboard(0&)
    Call EmptyClipboard
    Call CloseClipboard
    Do
        Call Tabelle110.Shapes("Grafik 2").CopyPicture( _
            Appearance:=xlScreen, Format:=xlBitmap)
        Set objPicture = PastePicture(lngptrCopy)
        If Not objPicture Is Nothing Then Exit Do
    Loop
    Set wb.Worksheets("Minus_final").Image3.Picture = objPicture
Aufrufen tu ich die Routine wie folgt, im Anschluß habe ich noch versucht, alles auf Transparent zu setzen, macht nur keinen Unterschied:
Call ShowPicture
Dim objShape As Shape
For Each objShape In wb.Worksheets("Minus_final").Shapes
With objShape
.Fill.Transparency = 1
End With
Next
Grüße
Mirko
Zitat von: Blaupunkt79 am März 15, 2024, 10:39:52ich habe folgenden Code aus dem Netz, um eine Grafik (transparentes gif) aus einem Excelsheet in einem Shape zu speichern. Im Shape geht allerdings die Transparenz verloren, wie erhalte ich diese?
Eine Frage stellt sich mir da vorab: Bleibt die Transparenz erhalten, wenn du das Bild manuell über die Benutzeroberfläche einfügst.
Blaupunkt79
Ja meine gif's sind alle Transparent, auch in den Excelsheets sind diese Transparent, wenn ich beispielsweise einige Zellen mit einer Hintergrundfarbe befülle.
