Gruppierung und Sperren von Datensätzen einer Tabelle über SQL Code
Begonnen von Mak, September 27, 2010, 18:22:18
Mak
Ich besuche gerade einen Basis Course in Database ohne grüble über folgende Aufgaben:
Create a list of stuff (showing only staff IDs in alphabetical order) who manage property with the properties they manage (showing only property IDs and addresses).
Mein Code:
SELECT Distinct Staff.staffNo, PropertyForRent.propertyNo, PropertyForRent.street, PropertyForRent.postcode, PropertyForRent.city
FROM Staff INNER JOIN PropertyForRent ON Staff.[staffNo] = PropertyForRent.[staffNo]
Where Staff.staffNo = PropertyForRent.staffNo
Order by Staff.staffNo
Also, group the properties together by their responsible person.
Wie kann ich dieses noch in meinem Code integrieren?
Create a view for the clients. The user should enter the maximum amount of rent that he or she is willing to pay, and the query returns a list with the specific details (full address, property type, number of rooms, and monthly rent) of all appropriate properties.
Mein Code:
SELECT PropertyForRent.street, PropertyForRent.postcode, PropertyForRent.city, PropertyForRent.type, PropertyForRent.rooms, PropertyForRent.rent
FROM PropertyForRent
WHERE (((PropertyForRent.rent) Between 0 And [Enter your Maximum of Monthly Rent]));
The user should not be able to change any details in the list.
Hier finde ich den entsprechenden Befehl nicht
VBA-Code habe ich gefunden: Application.SetOption "Standard bei Datensatzsperrung", 0 ??
Create a list of properties with full details, where the rent per room is also indicated (supporting shared renting of apartments).
Mein Code:
PropertyForRent.propertyNo, PropertyForRent.street, PropertyForRent.city, PropertyForRent .postcode, PropertyForRent.type, PropertyForRent.rooms,        PropertyForRent.rent,        PropertyForRent.rent\PropertyForRent.rooms AS [Rent per room], PropertyForRent.staffNo, PropertyForRent.branchNo
Hier würde mich gerne wissen wie ich hier PropertyForRent.rent\PropertyForRent.rooms
die Funktion Round(expression [, numdecimalplaces ] )
verwende.
Wahrscheinlich viele basic Fragen, aber einige Anmerkungen würden mir sehr weiterhelfen.
danke.
gruss
mak
Deutsch ist schon eine wunderschöne Sprache, vor allem für jene, die damit aufgewachsen sind.
Ich hasste es immer, etwas in einer anderen Sprache zu lernen.
Zum ersten Problem:
Ich kann mir eigentlich nur vorstellen, dass hier das einfügen einer Gruppierung gemeint ist - also:
GROUP BY Staff.staffNo, PropertyForRent.propertyNo, ....
Zum 2. Problem
Ich kenne keinen SQL Befehl, der das bewerkstelligen könnte, daher bitte hier nachlesen ...
http://www.fullaccess.de/CONT_EN_d9042481-dcb4-4f0c-a77e-68e183356ffc.aspx
Und Problem Nr. 3
verwende.
Nach Berichtigen des Divisionszeichens:  ----> ist kein Backslash sondern Slash!
Um das Ergebnis der Division mit 2 Nachkommastellen darzustellen:
PropertyForRent.propertyNo, PropertyForRent.street, PropertyForRent.city, PropertyForRent .postcode, PropertyForRent.type, PropertyForRent.rooms,        PropertyForRent.rent,  Round(PropertyForRent.rent/PropertyForRent.rooms, 2) AS [Rent per room], PropertyForRent.staffNo, PropertyForRent.branchNo
Hoffe das passt so?
;D
Grüße
Peter
