Das konkrete Datum wird in der Abfrage berechnet
Begonnen von benedictbrown, August 10, 2021, 05:36:44
benedictbrown
Why can't we live without a pressure washer these days?
You may feel that I am overstating this machine but the truth is the pressure washer is now playing a crucial role in our busy lives. The pressure washer can help to handle professional work that we had to hire a professional cleaning service before. In other words, thanks to this machine, we can save some money for cleaning contractors but still can remove all kinds of dirt like mud, pollen, mildew, and dried grass clippings. This is truly a power washer for home use. Let's see what a pressure washer can for our modern life!
Our house's beauty is destroyed daily because of harsh elements such as dirt, rain, grime, and sun rays. They degrade the house's long-term beauty if we don't spend time and effort to keep our house clean and tidy. Here are all the great benefits that a pressure washer can offer to our property.
Useful Reference: Highest rated pressure washers
Advantages of a good pressure washer for home
1/ Clean all kinds of dirt and tough stains
The greatest benefit of this machine is to allow us to remove all harsh elements such as oil stains in the garage, grease that normal cleaning effort cannot get work done. Even though we spend hours trying to clean the oil stain, the final result does not look much different from the beginning. Pressure washing can give our garage a completely new look in just half an hour.
2/ Save time and money
Most of us are busy these days but still want to keep our living environment clean and safe to protect the wellbeing of our family. For example mildew on the deck can be slippery while walking around your house. A high-quality pressure washer cleans the entire house in half an hour. How impressive it is! All kinds of dirt and stains are removable by high-pressure water. If you think the time is your money, this machine will be a way of daily savings.
Important Site: Say Goodbye to Grime with the Best Pressure Washer
3/ Enhance your house's value
Taking care of your house regularly is a way to increase your property's value. Your house is exposed to harshest natural elements every day that makes your house degrades overtime. Without regular and proper care, you will have to spend some more money to upgrade your house after several years. Pressure cleaning your house on a seasonal basis makes it look much more attractive as mold and mildew will be gone away.
To sum up
Top rated pressure washers can offer us many more advantages than these three listed above. Although they require your little investment, in the beginning, they add value to your life. Whether you would like to protect the health of your family or maintain the beauty of your house, choosing a good pressure washer is a wise step to do. Nowadays, this device comes at different shapes and prices. You need to know all the essential information to be able to pick the right model.
in der Abfrage neue Spalte:
Feld :   DifTage:  DateDiff("d";[Ausdr1];[Ausdr2])
Kriterium:  Tempvars!Tage
Statt einer Variablen erzeuge ein Tempvars-Element in einem Form-Ereignis und weise ihm die Tage aus einem Textsteuerelement zu:
Sub Button_Click)
Tempvars.Add "Tage", Me!txtTage
' hier evtl. die Abfrage ausführen/verwenden.
