Daten aus 2 Tabellen kombinieren
Begonnen von terryreynolds, September 10, 2021, 05:36:09
terryreynolds
Advantages And Disadvantages Of shark apex uplight vacuum
Shark apex uplight vacuum is always in the top best vacuum on the market voted by consumers. But is it suitable for your family?
The following Shark apex uplight review article will help you analyze the advantages and disadvantages of this vacuum so that you can make the best choice.
Advantages of apex uplight vacuum
Users love the uplight vacuum because of its outstanding advantages.
Compact and convenient design
Shark uplight weighs only 10.7 pounds with dimensions of 10.44 x 11.38 x 46.9 inches, very convenient for users. You will quickly move when cleaning and can store it anywhere in your house.
In addition, Shark designed an LED light for this vacuum that allows you to clean even poorly lit areas.
Capable of cleaning all surfaces
Apex UpLight will generate 66 CFM airflow to help you remove dirt from any surface. In addition, the machine also uses Duoclean technology that allows you to no longer have difficulty when you have to switch from floor to floor.
In addition, this vacuum is also equipped with some necessary tools: multi-purpose pet tool, crevice tool, built-in multi-purpose brush, accessory holder. You can attach these accessories to use different functions of the machine.
So it can be said, with Shark apex uplight duoclean, you can confidently clean everywhere in your house.
HEPA filter technology and anti-allergy system
Advanced HEPA filter technology will help you remove up to 99.7% of debris and dirt. Even nasty allergens like pet dander and pollen are thoroughly removed.
In addition, the anti-allergy system that completely seals the outer body of the machine will optimize the ability to absorb dust and protect the dust in the container. It ensures that the air around you stays clean while vacuuming.
With Lift-away feature
One of the advantages of most vacuums from the Shark house is the Lift-away feature.
With this feature, you can easily separate and move the dust cup with the push of a button. Then you can save time by carrying it with one hand and using the cleaning tool with the other.
This feature also helps you clean more flexibly in tight spaces such as stairs, under seats, car interiors...
Reasonable price
If you are a person who is influenced by price, this vacuum will be the right choice for you. Packed with outstanding features, this vacuum costs less than $180 with a 5-year warranty. This is a perfectly reasonable price.
Disadvantages of Apex uplight vacuum
Nothing is too perfect, and neither is this vacuum. Besides the outstanding advantages, the uplight vacuum also has a few minor limitations as follows:
Small capacity dust cup
The dust cup of apex uplight can only hold about 0.6 liters which are pretty small if you have a large house.
However, a dust container with a transparent plastic layer will help you recognize when the container is full and promptly empty it. It will take you a bit of time, but what the machine gives you is completely worth the experience.
Limited power cord with large space
Because it is a wired vacuum, when you use it, you will be limited in space. With a 30-foot cord length, this means you'll only be cleaning around a power outlet within a 30-foot radius. As with the above drawback, it will take you time to move the machine to the sockets.
Thus, the above article has given you the advantages and disadvantages of Shark apex uplight lift-away duoclean. Although there are some limitations, the outstanding benefits you will receive are entirely worth it. We hope you've decided for yourself.
vermutlich ist das überflüssig, Du hast ja die Daten schon in einer Tabelle, wozu nochmal in die 2.Tabelle?
Bitte mal genauer beschreiben.
Wie sind die Tabellen aufgebaut?
Welche Beziehungen sind angelegt?
PS:
Ich habe den etwas merkwürdigen Titel geändert.
