Check the status of attachments in the database
Begonnen von eugenewright, September 18, 2024, 11:32:02
eugenewright
Hi guys, How to check if file is stored in attachment field? What I want is that when uploading an attachment for a document there should be an output status column of "Completed". This is very convenient.
Does anyone know how to use the query? Thanks!
Knobbi38
Hello,
Attachments are provided as recordsets in a DAO.Recordset2. This can be opened and then you can determine the number of records in the recordset.
For an example of access, see here:
https://learn.microsoft.com/en-us/office/client-developer/access/desktop-database-reference/recordset2-object-dao
